hotdimmes
If the question is how fast is the Contour V6 capable of going, I'd say between 140 and 150. The SVT has a 140mph speedo IIRC.
svt speedo = 160mph, top speed drag limited to 143mph.
His original question was the top speed of a v6 ATX Mystique. Man... you guys are all over the place. :laugh:svt speedo = 160mph, top speed drag limited to 143mph.
i would say something about the zetec and hitting the governer, but i dont want to get bannedI can tell you a Zetec with like 150k miles has a tough time reaching the limiter, and it's not that rough when it hits it. Just decelerates to about 105 then gets power again... repeats that over and over. Quite boring, actually. Same in my Sentra... hits 130 with an uneventful slow down.
What's rough is a 95 9C1 Caprice with a 3.75 rear end (stock is 3.08) and stock VSS hitting the 125MPH limiter. It would buck like someone first learning to drive a stick. Of course, the car was actually going much slower, but the ECU sure thought so).
Ford says 143mph, but it's been proven many times that you can go right past that.
To add to your comment though... I'm sure you'd need a huge stretch of track to get to that speed. Takes a bit of time just to get from 130 to 135.
ahh ok. I knew you had to be asking something other than what I smugly replied to.
there is a difference in exactly what happens. the rev limiter does just pull the timing however the governer wants to slow you down. the easiest way to do that without applying the brakes is to pull the fuel and ignition and let the engine be a big air pump and add lots of resistance. Just like AJ said, it bucks HARD when you hit the governer.
I had bounced the governer on many occassions, and it never bucked hard, just slowed you down a little, whats all this buck HARD crap? Never happened to me in my v6 ATX Tour!?
I dunno but the first time I hit it in my zetec I thought that I broke something the way it cut out
weird, i have hit it in my wifes gl auto, and in my se v6 auto, and it never bucked at all, is yours a manual? maybe it hass to do with the auto versus manual?
i suspect its more of an MTX vs ATX thing. since my Zetec MTX with PRT RR bucked hard off the governer. :shrug:yeah I have a manual but it could be any number of things, like say the roll restrictors being shot and the engine unloading at high rpm and speed ... who is to really say :shrug:
1) Non-SVT Contours are speed limited to approx 115mph by the PCM because of the speed rating of the OE tires. The limiter is largely done by fuel cutoff in the calibration, though many factors can affect exactly what happens between the fuel and spark. This is NOT the same as the rpm limiter, which always cuts fuel and spark to prevent over-revving the engine.
I can vouch that a V6 MTX really jerks when you hit ~118 or so and the power cuts.
Rara is absolutely correct about non svt tours going only 115. I tried this once when i was driving home from XXXX to XXXXX.... i was falling asleep and wanted to wake up... so i slammed the throttle and found my meter reachinng 110, when it got to 115, the rpm just cut out... and that was that... ATX, 170k...
