mrdennis87
- Joined
- Apr 3, 2011
- Messages
- 18
If I was to upgrade the cam, could anyone tell me intake/ exhaust size or link me too One that will fit..I have the 2.5 Svt motor..Dohc..and am looking for ways to add horsepower..
Trevor Jasper @ Revolve/Mountune said:Mike,
We do have three different profiles for Nobles, all of which are proven to work. We guarantee that you will have no piston-to-valve clearance issues - there is over 220thou valve-to-piston at TDC. You absolutely will need to buy some valve springs/retainers too, as the lifts - between 11.1 and 12.2mm depending on camshaft choice - will force the standard springs coil-bound.
Usually, we re-profile the customer cams, but occasionally, we send out reground cams as an outright purchase, which I would assume you'd like? Alternatively, we can supply new blanks with slotted-hole pulleys for optimum timing, though they are more expensive.
Hope that helps, and sorry for the delay in replying.
Trevor
David Newman @ Newman Cams said:Hello Mike,
If you phone Ken Newman on 016898 57109 he will discuss the options that he has on this engine,this will be more informative than of E Mails.
Regards
David Newman
<david@newman-cams.com>
Dave Crower @ Crower Cams said:Michael,
Good morning. We are doing regrinds only on that motor. Send them in to us along with these forms.
Thank you,
Dave
<dave@crower.com>
mc
Charley @ Futral Motorsports said:Mike,
I read the link but I think that they mean "FMS" Ford Motor Sports not us. I talked to our cam grinders and they showed me to cam cores that they have for your engine. There phone number is 1-225-926-6110 or http://www.cammotion.com/Default.aspx . I hope this helps you find what your looking for.
Charley@FMS
CJ @ VAC Motorsports-Cat Cams US Distributor said:----------------
Hi, I found on the Cat Cams website that you are a US dealer of their products. I'm interested in purchasing a full set of cams for my Ford 3.0L Duratec engine build. I'm curious about pricing and availability on the following cams below. I'd also like to verify that the one cam has the provisions for the water pump pulley. Please let me know if you would be able to help me. Thank you.
Cat Cam P/N
2394064
2394068
2394070
Best Regards,
Mike
Hi Mike,
That camshaft (as well as the ones you inquired about) run $1394.95 per set plus shipping.
Regards,
CJ
(Chris Jurkiewicz)
VAC Motorsports
Sales & Tech: 215.462.4666 Ext. 15
Fax: 215.462.4667
www.vacmotorsports.com
