Barge
OK, since i'm kind of drunk right now, this is a good time for me to have a little technical discussion on here to try to prevent people from agitating my sense of correctness.
Now I'm not going to expect all of you to understand what a compressor map is for a turbocharger, let alone any type of turbine map you might find (yes, they do exist, although fairly rarely... garret has them for their GT series turbos)... so let's get on to the goodness.
Since i've already stated that most of you probably have no clue how to interpret a compressor maps (you should if you're getting a turbo... it's the sensible thing to do) let's try to avoid using the word "Lag" unless we really mean it.
When most people refer to "lag" they are actually referring to what more correctly would be termed as boost threshold... what's the difference you may ask? Well let's see if we can delve a little deaper into this.
If you were to study a compressor map, or a turbine map if you were lucky enough to find one, you would discover that turbo's don't just magically create "boost". A compressor map can tell you at what flow rates and at what pressure ratio (boost in a sense) the turbo can actually operate. This is what makes the study of a compressor map so critical. If a compressor maps shows that a certain compressor wheel can't flow 300 cfm (yes, technically most compressor maps should be in a more mass measurement but because few people understand the difference and cfm is easier to use and can be converted to at standard temp and blah blah.. we will use cfm) until it's at a certain pressure ratio... or vice versa... then it's just not going to happen... no matter what kind of voodoo magic you want to perform to make it happen.
This, ladies and gentlemen, is boost threshold... if the turbo's not gonna flow enough at at a pressure ratio it ain't gonna happen no matter how hard you try. Although this efficiency can be influenced by the turbine wheel, but then we're getting into trial and error type testing.
So what exactly is lag? You should all be asking yourself this by now...
Lag would more correctly be defined as what happens when you're at a point where the engine can consume enough air that the turbo can supply enough air to create a certain pressure ratio and the "boost" takes x amount of time to actually happen. For most systems this is actually a negligible amount of time. For example.. take a turbo contour and punch the gas a say 1500 rpm... boost pressure will not build until.. ohhhh.. say 2500 rpm (depending on turbo charger).. this is boost threshold... however if I'm over 2500 rpm and punch the gas.... the time for is to develop an amount of boost it would normally be able to create at said rpm is lag.
OK... I think that all makes sense. Time for bed.
