Just wondering if anyone has had problems with the alignment of the y-pipe like I THINK I have. The original y-pipe on my contour SVT attaches to my borla system at an angle of 10 or so degrees off center, the trubendz is welded 180 degrees horizontally. I contacted Trubendz and they said the WHOLE pipe is made at an angle so it fits to the original layout?If you lay the two flat on the floor the Ford unit is at an angle but the trubendz is flat? I didn't tighten the front flange all the way snug but I tightened the rear cylinder and the hanger which went on the original stud was tight but there was no way I could see how the pipe was going to twist enough to line up with the rear flange. It needs to move about a half inch to allow the bolts thru. If anyone can give an idea or two so I don't keep calling the guys at trubendz liars ,please respond, thanks
