dragan
Be Gentle I'm New Here
I have Contour sport '97 V6 automatic, 115,000 km on the clock.
All of a suden I got transmission fluid backing up through that little pipe where you can check fluid level.
While driving, gears are kinda slipping, it feels like when you drive manual transmission and press and release clutch all of a sudden. Engine revs up until transmission engage again and then it's all ok for a while
Mechanic told me that is either pump or some bearing inside that doesn't hold and is releasing presure and causing fluid to back up that pipe.
To be able to tell, he need to open it up and check, with price tag between 1500 - 3000...
Did anybody had similar problem, and is that mechanic telling me the truth, or is usual story when you go to them "auuu, you have huuuuge (read expensive) problem..."
Thanks
Dragan
Thanks
Dragan
