Lord Stanley
Gates kit comes with a tensioner spring, don't worry.
No it does not, at least the kit for my '95 did not... Greg was still able to get the tension spot on without one though...
the only thing you need is the timing kit and valve cover gasket (unless is been replaced recently and then you could probably get by without replacing it). the crank bolt is not TTY and there is no timing belt cover gasket.Don't know if mine will have the spring in it. Early ones didn't, as I understand it, but I'll order the gates kit. What else does one need: valve cover gasket, crank pulley bolt, timing cover gasket?
I know his will alll seem simple after I've done it but you know how it is....... until you do it, it is still a mystery.... LOL
AF
What old spring? 95's FTW :laugh:Regardless, you can use the old spring.
I was going to say, my 97 didn't have one either.What old spring? 95's FTW :laugh:
There should be about 1/4" of play up and down on the belt between the cams after tension is set. The top of the tensioner is hooked onto the engine, and then bolts it. What you can do is bolt in the tensioner at the "least tension" setting, and install the timing belt, making sure the teeth line up correctly on the cams and yadda yadda. When you do this, the play between the cams will be about 1.5" or so...pretty loose. Loosen the tensioner bolt, and use an allen wrench to adjust the tensioner, then tighten the tensioner bolt. Then double-check the tension as I had mentioned early between the cams. If it is too tight or too loose, follow the same procedure and check again.So what do you do to set the belt tention w/o the spring and not over tighten it?
