KyleQ
Sorry don't see too many Mercede's and Porsche's driving around in Minnesota...
i suggest you all look at http://www.siemensvdo.com. they have THOUSANDS of gauge ideas/solutions that are simply worth while. i believe they have been around ALOT longer then autometer and do TONS more stuff, and imho, better quality, better prices, more selection, and better service cheers
Brass tubing all the way up the pillar? No thanks. I picked up the electric short sweep one and got it on Saturday. After all day I have it hooked up and working.
Works pretty decent if you ask me Reading the same numbers as the mechanical Ford Racing one was when I had it.
This is what you read no your oil pressure gauge? Is this normal?
Wow. Maybe my gauge is off (or normal)? When cold, it runs about 70psi then drops to 30 or so.
No it depends entirely on where you mount the pickup Different parts of the engine have different oil pressures. Mine is mounted down by the oil filter in the block.
VDO is the best brand out there but it's overpriced (my opinions)
