Ford has stopped producing pistons for my Duratec 30 (Escape) and only sell the short block now. Since I want to build it myself and the cost of the Short block is more than a re-build kit and the custom pistons... I have some things to consider.
I was running a KB supercharger but the tune was not quite right it seems. Even though I could not hear any knock I seems I got it and I broke some ring lands on one piston. I know a better tune (dyno) is in order but first I must work the block.
So on to pistons. Any suggestions on brand? Should I lower the compression (I'd like to run my 9 lbs pulley again)? What should I lower it to if I do ( 9 1/2, 9)? What would the lower compression do to off the line and low end performance? Would I need to change anything in the tune to compensate for the lower compression ( I don't think so but thought I'd ask).
THanks in advance for any help here...:help:
