S Static CEG'er Joined Sep 17, 2002 Messages 97 Location Livin on Tulsa Time Nov 2, 2006 #1 what all is required on the TB side of doing a 3L swap. I am doing a full 3L with the 3L lim, uim, and tb. what all do I need to be aware of
X XKontour98 Hard-core CEG'er Joined Sep 18, 2002 Messages 1,358 Location SE Minnesota Nov 8, 2006 #2 Not sure if you have an SVT or not, but I believe all you would need is the SVT TB cable/bracket if it's a non-SVT. If I understand correctly the 3L TB and SVT TB are the same.
B Big Jim Hard-core CEG'er Joined Sep 3, 2000 Messages 2,899 Location Thousand Oaks, California, USA Nov 11, 2006 #3 They are not the same. The castings are the same, but the finished product is quite different. They are the same diameter.
9 96BlackSE CEG'er Joined Aug 15, 2002 Messages 339 Location Ottawa, Ontario Nov 11, 2006 #4 The newer taurus and escape TB's are not the same as the SVT tb or similar to it... It was the older TB's on the taurus's with metal UIM's which were the same casting You basically want to use the Taurus TB and mod the throttle body bracket so you can use your existing throttle cruise cables
