it's not oiled, hence the bearing problems. the bearings are sealed and do not require oiling, and are rated for 100,000 RPM (yes i typed that right). at the boost level i'm geared for, it's pushing something like 54,000 RPM, which is fine. the problem with this is these bearings cannot handle much side pressure at all, and the bearings are so close together that the side pressure is rather large. the belt is cogged so it doesnt have to be tensioned hardly, but the torque on it is still there. i know how to fix it but it's gonna be hard to fabricate the part. i'tll basically go around the front of the pulley to the other side and it would have a third bearing on it so it would have a bearing on each end one in the center basically and this would virtually eliminate any side pressure loads.... (the twisting motion)
