When you bolted that shackle between the rack and the steering column.... did you have to rotate the steering column to get the correct spot for the shackle to swivel closed ? It just doesn't seem right that 1 spline tooth could throw the steering wheel so far off.
Been a while since i shoved my head up there, but i think that shackle comes off the bottom of the steering column.
You can center the steering wheel, line up the shackle with the correct spot on the rack shaft, (mark the shackle and the steering column, coz everything moves and is a bit tight for space), before sliding the shackle back on the end of the steering column.... G.
