hi all,
have started to remove the st24 engine, and have reached a couple of difficulties
1 how do you seperate the fuel lines from the rail
2 what is the procedure for disconnecting the gear changing cables from the gearbox, are disconnections made at the gear stick, or do you remove the housing and bracket from the gearbox
thanks
thanks
