bigboyricky93
Hi-Def Porn King
******UPDATE!!!!! ALL ITEMS ARE NOW FREE! PLEASE READ POST #7 BELOW FOR DETAILS! Merry Christmas!******
Stallion Build Parts Sell-Off
--All 3L parts have only 12,000 original miles on them and are from a 2005 Sable… they are barely broken in and in great shape.
--All 2.5L, SVT, and original parts from my 98 SVT have138,088 miles on them unless otherwise stated.
--All seals and gasket equipment is new from a fel-pro kit I ordered
--All parts are “as-is” as I cannot test them or do not have time to test them.
--All prices include shipping for CONUS (for Alaska,Hawaii, and Canada please ask.)
--All items will be shipped the Monday following payment recieved
--Larger Items are marked for local pickup only
--Ask for pictures
*** ASK ABOUT BUNDLING ITEMS OR LOCAL PICKUP FOR DISCOUNTS***
3L Parts (all 12,000 original mi)
· UIM - $50
· IAC - $25
· EGR - $25
· Throttle Body Combo - $40
o Throttle Body - $30
o Throttle Position Sensor (TPS) - $20
o Throttle Cable Bracket - $10
· Timing Equipment Full Set (2 intake &exhaust cams, two chains, crank sprocket, guides and tensioners) $85
· Vacuum Hoses - $20
· LIM - $30
· Coil-on-Plug (COP) full system! - $40 PENDING
· Wiring Harness- $40
· Water distribution pipe - $25 PENDING
· Water thermostat, housing, and pipes - $25 PENDING
· Water head crossover tube - $25 PENDING
· Water pump pulley - $15 PENDING
· Water pump belt PENDING
· oil pressure sender - $15
· Pulse wheel - $15
· Sable Oil Pan - $25
· Sable Pickup Tube - $15
· Sable dipstick - $10
· Timing cover - $30
· Black pulley extension off harmonic balancer -$20
· Harmonic Balancer - $25
· Flex plate - $15
· Left (radiator) Sable header with O2 - $35
· Left (radiator) bracket plate where A/C wouldgo - $15
Original/2.5/SVT parts (138,000 miles)
· Water pump w/o tensioner - $25 PENDING 2 TIMES
· Power steering pump, bracket, and pulley (hasa leak somewhere possibly just needs new rings) - $20
· Timing cover (may have possible leak… or not,it may have been just a leak running down it from p/s pump. Don’t have time to check or test. - $20
· Oil pan (has confirmed leak that may be ableto be welded near tranny side of pan) - $15
· 2.5 Oil pickup tube - $15
· MTX-75 Transmission ***LOCAL PICK UP ONLY***- $40 PENDING 3 TIMES
o Comes with bell housing and case separated (Ihave all the bolts except for the ones with studs for shift linkage bracket)
o Differential has 60,000 miles and chippedteeth
o 1st and 3rd gear grind
o Has used throw out bearing
o Will come with the plastic green worm gearfor the VSS but will not have VSS sending unit
o GOOD UNIT FOR REBUILD!
· I also still have my 2.5L block without theintakes, timing equipment, or oil pan… It has the spun bearings and I’m notsure if I want to try and rebuild or sell it off altogether or by parts… If interested don’t be afraid to send a PM. (Would be local pickup only if I choose to sell)
NEW gaskets and seals from Fel-Pro kit- ALL SOLD!!!!
· Right and left head gaskets -
· Bag of 24 valve stem seals
· Bag of 21 valve cover grommets
· 1 throttle body mounting/gasket
· 1 air bypass gasket
· 1 EGR gasket
· 6 o-rings
· 6 sealing o-rings
· 2 camshaft rear seal
· 1 water outlet o-ring
--Ask for pictures
· UIM - $50
· IAC - $25
· EGR - $25
· LIM - $30
· Pulse wheel - $15
· Flex plate - $15
· 1 EGR gasket
· 6 o-rings
· 6 sealing o-rings
