JohnHoward
Hi,
I have a rusted leaking rear brake line on my '95 Contour just forward of the passenger rear wheel. I was going to replace the entire line but discovered that there is no easy way to reach the front connection without taking the car apart. But you can reach the rear connection. So I plan to do what others have done and splice in a new section of brake line to replace the rusty piece.
Reading some of the older posts here, it seems like I will need to cut the bad section out of the old line and then make a new double flare on the piece that's left. Then I can fit a universal piece of new brake line where the old piece was. I will also need to use an adapter or union where the splice was made in order to join the old and new lines together.
Has anyone done this? Any tips or advice on the process and parts needed will be greatly appreciated. I see some discussion between "double" and "bubble" flares, but don't know what kind the Contour has. Anyone know? I measured the OD of the brake line and it seems to be 3/16 inch. All the double-flare kits have an adapter for that size. I'm guessing that's what I need.
I did brake lines on a Ford Tempo a few years ago managed that okay but have never made a flare on an existing line. I've searched the older posts and found some info but not a great deal. Your experiences and input would be a great help to walk me through this. I live in a rural area and need to do this myself.
Thanks!
Thanks!
