CSVT#49
Addicted CEG'er
So I think I'm set on buying the Siemens Deka 80# EV1 injectors. However I've never really heard of Siemens Deka. Does anyone have experience with them?
they are what ill be running as well now that im building the motor. I know alot of the cobra guys/ turbo cobalts uses them and have had no issues. they are on pretty much every website that offers fueling up grades.
how much power do you expect to make? both on 93 and E85?
Edit: you can PM it to me if you dont want to post it, but i ask because I think 1000cc injectors are a little big and you would do better with a smaller injector.
thats quite a bit of power, in which case yeah the 1000cc injectors should be enough.
I prefer to use .5 to .55 for intercooled turbo engines, which would put the 1000cc right on the money.
yeah id suggest a second pump i will be doing the same and remaking my fuel pump assembly. The stealth and 3kgt people are using twin walbro's to be on the safe side.
I think the pump would be ok, but it would probably be right on the edge, depending on just how much power you actually make. if you are using all 1000cc/min of the injectors, thats 6 liters/min of flow, or 360 liters/hr. that said, you mostly likely wont be using the full 1000cc/min of the injectors, and if you do it will almost certainly only be at peak HP, which will only last for a second or so. that said, since its a return style system, its not really possible to have to much fuel pump as long as you have an adjustable FPR to deal with the extra flow (which im sure you will).
This might be of interest to you Mike: http://www.newcougar.org/forums/for...s-procharger-build-updated-7.html#post1822823
