primalzer1998
It seems like for what most of the people on this forum do, and their driving style the B&M seems like a fine choice.
About the centering spring, you don't need it.. so you won't have to worry about that hassle.
If it's sloppy w/o the spring, then one of your bushings is probably worn. When doing either of the short shifter installs, you should replace the flared lock bushing on the drivers side, and the white bushing that snaps on to the end of the shaft that comes off the passenger side of the ball.
I didn't do that when I installed my Steeda. I recently replaced the front/back cable end and no longer had that direction of slop, but I noticed I had side-side slop. I replaced both of those bushings and now there is no longer any slop anywhere... very crisp! You need to remove both of those bushings to install either of the short shifters, so you might as well spend the ~$8 and put everything back together with new bushings.
reebs, are you referring to the steeda or B&M shifter? Did you change your bushings?
