Fujitsu Stylistic ST5021 Tablet PC w/extras
SPECIFICATIONS
[FONT=Verdana,Arial,Helvetica]Microprocessor
Intel® Pentium® M Processor Ultra Low Voltage 733
(1.10 GHz, 2 MB L2 cache, 400 MHz FSB)
Operating Systems
Microsoft® Windows® XP Tablet PC Edition 2005
Display
10.4" XGA LCD indoor/outdoor viewable display; optimized for "true" outdoor viewing
Digitizer
Electromagnetic (active) digitizer
Chipset
Intel® 855GME
System Memory
Two DIMM slots available; 512 MB SDRAM, maximum memory to 2 GB (1 GB x 2)
Memory Type
DDR333 MHz; 200-pin SO DIMM
Hard Drive1
40 GB ATA 100 4200 rpm, shock-mounted hard drive
Video Controller
Integrated Intel® Direct AGP graphics with up to 64 MB Dynamic Video Memory Technology
Audio
[/FONT][FONT=Verdana,Arial,Helvetica]SigmaTel® STAC9753A AC-97 rev. 2.3 compliant; 20-bit audio with a built-in mic, stereo headphone and mono microphone jacks
Environmental
Operating Temperature (with power management): 41° to 95°F (5° to 35°C);
Humidity: 20% to 85% (non-condensing)
Non-Operating Temperature: 5° to 140°F (-15° to 60°C);
Humidity: 8% to 85% (non-condensing)
Communications
Multinational 2 56K3 V.90 modem, 10/100/1000 Base-T/TX Ethernet, and Intel® PRO/Wireless 2200BG Network Connection (Wi-Fi® certified 802.11b/g); diversity antenna
System Ports
2 USB 2.0 ports
Infrared port (IrDA 1.1-compatible, 4 MBps)
External monitor connector
Modem (RJ-11) jack
Ethernet (RJ-45) jack
IEEE 1394 connector
Wireless IR keyboard receivers
System interface connector[/FONT][FONT=Verdana,Arial,Helvetica]
Security
Trusted Platform Module (TPM); dedicated Smart Card reader slot; Fujitsu Security Application Panel; Kensington lock slot[/FONT][FONT=Verdana,Arial,Helvetica]PC Card Slot
One Type I or Type II slot; 32-bit PC CardBus architecture
Media Slot
One shared slot for MemoryStick and Secure Digital (SD) card
Battery/Life4
Standard lithium ion; (6-cell 10.8V, 4800 mAh); rated up to 6 hours4 using main battery; 51 WHr capacity
High-capacity lithium ion (9-cell 10.8V, 7200 mAh); rated up to 9 hours4; 77 WHr capacity
AC Adapter
Auto-sensing dual voltage support, 100-240V AC; DC 16V, 3.75A
Dimensions/Weight
Standard battery ; 12.77"(h) x 8.66"(w) x .82-.88"(d); Approximately 3.5 lbs.
High-capacity battery ; 13.5"(h) x 8.66"(w) x .82-.88"(d); Approximately 3.9 lbs.[/FONT]
EXTRAS
Heavy duty nylon protective case with high density foam inserts & pen holster. (100% functionality in case, on all ports). Flexible nylon/rubber handle. Elastic bands and D rings for mounting options. Slimline.
Original software pack including MS OneNote 2003, System Restore Disk (Winxp Tablet Edition 2005), Driver & utility CD, Driver & application restore CD.
WHY YOU NEED IT
The same reason Im keeping my other one. Mount in car, hook up USB camera and record. Plug in Elmscan or other OBD-II scanner for full heads up display and datalogging. Infinitly better than your gauges.
Wireless comes in handy if your on the road and need to hit a hot spot for info/directions/etc.
INTERESTING TRADES WELCOME
