95tourdn9
i have looked through a lot of posts looking for a post on how to remove the reverse lock-out on my 95 tour se...after awhile of looking with no results I decided to just go out there and figure it out my self...its pretty easy so I thought I would share it with everyone. And I know what everyone says why not just leave it, well I wanted to shorten my shifter so I would have to cut out the lock.
First your going to want to remove the shifter knob, and boot. On the side of the reverse lock-out ring there is a pin you have to pull out then remove the lock out ring, where the shifter and the floor meets there is another boot you need to pull off, under that is a c clamp that next needs to come off once you have that off pull the whole shifter out of the car, on the bottom of the shifter there is a rod that slides up and down push it up and on the top of the shifter you will see a cable and bulk head where the pin held the lock out ring in, cut the cable and pull the rod out of the bottom, re-install the shifter....and thats it i dont have my camera right now so i dont have any pics...ill try to post them as soon as i can
