Depending on where you go for install, and also dependent on if your vehicle is a Manual or Auto transmission the install price will vary 150- 250. You will need a PATS bypass module 20 bucks, and need to have a second key programmed 50-100 bucks for your car if you dont have one, clutch bypass is necessary (even though its only a relay) 25 bucks, In the end, on a cold day, when you dont wanna run outside, its kinda nice, but also, as you may have read, if your battery aint up to par for WHATEVER reason, youll be an unhappy camper. I do have a remote start on mine, Im in Minnesota and it gets cold up here once in while, but be prepared for that ONE day out of the year, that your car may not start. my 2 pennies.
But just for fun here you go....2000 Ford Contour Security Information
Constant 12V+ Red Ignition Switch Harness
Starter Gray/White Ignition Switch Harness
Ignition Green Ignition Switch Harness (heater)
Accessory Orange or Red/Blue Ignition Switch Harness
Tach Brown/Green or Brown/Blue Coil Pack, Use 2 Cylinder Setting
Neutral Safety Wire Black/Yellow Switch on Driver's Transmission
Brake Switch Orange/Yellow or Orange/Black Brake Switch
Trunk Release Orange/Green (+) Switch or Keyless Module behind Glove Compartment
Trunk Pin Black/Red (-) Keyless Module behind Glove Compartment
Parking Lights Red/Blue (+) And Red/Yellow at Light Switch Harness
Head Lamp Orange/Yellow (+) Light Switch
Factory Disarm Yellow/Purple (-) Driver's Kick Panel
Door Trigger Blue/White (-) Courtesy Light under Dash
Door Lock White/Green (+) Driver's Kick Panel
Door Unlock Yellow/Green (+) Driver's Kick Panel
Driver's Lock White/Green Left Kick Panel
Driver's Unlock Yellow/Purple Left Kick Panel
Passenger Unlock Yellow/Green Left Kick Panel
Horn Wire Red/Orange (-) 3 Pin Black Connector at Steering Column
Windows Up LF=Yellow, RF=Yellow/Purple, LR=Yellow/Purple, RR=Yellow
Windows Down LF=Yellow/Green, RF=White/Purple, LR=White/Blue, RR=White
