hotdimmes
So I'm changing my rear brake pads, using pliers to twist the rear brake cylinder clockwise as I've read a million times, and it just wont go any further even though it has to, to accept new pads.
similar to this thread:
http://contour.org/ceg-vb/showthread.php?t=2141&highlight=rear+piston
Not sure what to do and I need help by morning! Did front drivers side pad, put everything back on, went to driver's rear, then ran into this problem. Hadnt pumped the brakes since doing the front, so I tried that and the rear piston came out to the rotor like it should have. We were able to turn it back to its original position so it accepts the old pads but thats it! Cap is off the reservoir. Ebrake is down. Is that maybe the problem?
