Python Alarm - how to add trunk pop?
posthuman63t
Wisconsin
I have a Python 700 alarm system on my car that I had installed this past summer. The remote has an accessory button on it that can be used as a trunk popper. Since our cars pager (lock/unlock/trunk/panic) has the trunk popper on it, I assume I have the capability to just have my current alarm pager have the trunk popper on it.
Anyone have any hints to doing this, or is it something I'd have to bring in and have them do?
(btw, I had Circuit City do the alarm. Alarm works great!)
You have to hook up a relay to the trunk wire. Coming off the accesory output on the alarm
Trunk/Hatch Release orange/green + release switch
Also found at the keyless module located behind the glovebox, high in passenger kick panel. There are two yellow/purple wires - one unlocks drivers door and the other unlocks the rest of the doors. These two wires are common at rest through the keyless entry module. Diode isolate and pulse (+) to operate. Lock is white/purple at keyless module
close
