joepage
Well I know its been a while since we updated this thread so...... After a break for the holidays last weekend we got the good motor in, UIM and LIM back on, front end all back on, all the wiring hooked back up, suspension hooked up, and after destroying the vac line then piecing them back together it was time to fire it up. Amazingly it fired up in about three cranks! Of course we started celebrating a little to soon. We had a fuel leak from around the injectors. Pulled the UIM and reseated all the injectors, put it back together again and of course destroyed the cold brittle vac lines AGAIN, (wiill replace with silicon) but had enough to fix it. Chris left to go back into the Marines the next day so as usual left me hanging. I got the vac lines back on and it fired right back up. this time no leaks! I let it idle for 20- 25 min, long enough for the temp to rise. So far no codes! Not warning lights! Only thing left is to fix brake line (just need to cut it, replace fitting and reflare), shift cable end should arrive in a couple of days( pop out the bushing and pop in) hope it doesnt heed adjusting, hook up the exhaust, recheck all the bolts and get it aligned.
I will get some pics up soon for anyone that is interested.
