SVTJON87
ok guys im going to order honey and this is the part# i have XTM5QS. when i put it in on team ford it says "FLUID - AUTOMATIC TR". also this would be im guessing changing out the atx fluid. should i just drain and fill or flush it somehow. and should i change it when the trans is warm. thanks guys
edit: yes i have read up alot on this matter. as terry has said" stay away from FM if you can unless you have a probmel with the lube". what im wondering is how will i know if im having a problem with my lube. god i sound like noob.
