Red99CSVT
So I just Got done changing my A/C compressor, changing brake fluid and a few other things on my SVT. I connected the battery and turned the car over...not firing just spinning over. I connect the Modus scan tool I have access to and I get P0605-Internal Control Module ROM Error. This sucks!!!!!!! I can see all my values change when I crank i.e. rpm, batt volt, injector pulse width, short term fuel trim, even tps voltage, eng coolant temp, etc. The only thing I can do now is buy another PCM and take the car to Ford because the PATS has to be reprogrammed before anything will work after changing the PCM. Just **sses me off. I've put a lot of work into my car and a part that "never fails" does just that.
Shotwell-I tried to call you today to see if you've ever heard of this problem
