w4wlr
Well, I had several of this code come up in my '99 Duratec Contour SE Sport. Changed out the fuel filler cap; no joy. Got the code again!
I decided to take a long hard look at the top of the engine and found a rubber hose that looked in bad shape. It started from the air cleaner intake pipe and went under the engine cover (the plastic one near the front of the engine compartment). When I removed the cover, I found the hose had totally disintegrated under the cover, opening the evaporative emission system to the atmosphere. This hose is part rubber and part plastic and passes over the top of the water pump pulley and connects to the valve cover.
Went to the local Ford dealer and got the new, updated hose for $25 or so. Car now runs smoothly and so far, no repeat of the code.
Thought this might be helpful to someone here.
