shotwell
Hi all! Thought I'd share my recent drama with the ex-wife's Contour.
Car kept coming up with P0171 code. That's Bank 1 Lean so you don't have to look it up. Lots of people have trouble with this code, some even calling it the code of death! :crazy:
(The car is a Zetec ATX, 2000 model year. The same one Aussie and I changed the timing belt on earlier this year. Has over 220k on it.)
I did a lot of searching here and elsewhere to find solutions. Learned that OBDII systems don't like vacuum leaks. Check.
Followed some people's advice...cleaned the MAF, check fuel pressure, check air box O ring, check tube beyond MAF for cracks, etc, etc. No joy. I found a cracked vacuum line right by the throttle body. Fixed that and sent it out...code came back.
This is where I call up my good buddy Aussie for reinforcements. Today we went over it with a fine toothed comb. Found ANOTHER cracked vacuum hose, although much worse. It's a curved hose that goes to the transmission (I think). Goes from a canister under the intake to a pipe near the thermostat housing.
Once the hose was replaced (with a slightly modified version) the car idled a little better and drove A LOT better, at least compared to reports my ex-wife gave me before I picked it up. I drove it about 50 miles total, shutting it off and restarting at least five times. No codes so far.
Fingers are crossed!
