The plugs have about 10,000 miles on them, maybe less. Autolite Double Plats. What I've checked:
I'm not totally convinced it is a problem with the injectors or fuel-related. Especially because of the fact that it runs fine with the engine above 1000 RPMs, and is only affecting idle.
The part that is puzzleing me is the steady surging between 600 RPMs and about 900 RPMs, rhymically, only when stopped and sitting, like at a light or in a parking lot. And it seems worse when the car is warm.
Does any of the above sound like symptoms of a dirty/sticky IAC? Or maybe the O2 sensor actually going bad? Or anything else?
- All 4 plugs, and the gaps. Fine. Plugs looked normal.
- All 4 plug wires, and connections. Fine.
- Removed entire air intake, including plenium, and ran quickly w/ the throttle exposed to open air to see if it was an intake problem. Everything ran just as bad.
- Partially pulled off timing belt cover, checked integrity of belt, and watched it while the car was running.
- Had the codes pulled 3 times, all 3 times it was the P0171.
- Cleaned the MAF. Made a little difference but got worse right away. I just blasted it but I'll have to try cleaning it with a pipe cleaner.
- Checked the entire engine multiple times with carb cleaner and heard no difference in idle.
- Visually inspected everything very closely. Nothing obvious.
- Check belt, hoses, etc.
- Had the charging/electrical system tested. Everything tested good.
- Checked all fluids, especially oil, all perfect and changed recently.
- PCV valve changed 8,000 miles ago by the dealer.
