is it normal for oil to sometime get into the turbine or leak out between the turbine housing and the center cartrige? I am assuming not.
last friday I bypassed the turbo and was idling the engine and reving the engine. I was doing some data logging and the car started smoking. now every so often recently I have gotten alittle smoke off the turbo, was thinking it was the oil drain leaking alittle as it has been doing that. well after it smoked I turned it right off.
first drive after that with everything back to normal it smoked for a few minutes lightly and then cleared up.
last night when I drove it I didn't note any smoke at all.
now I do know it hasn't been making as much boost as it had been at part throttle. full throttle is fine, but I attribute that to the leaking wastegate gaskets.
so what I observed when I pulled the turbo tonight was oil had been leaking out between the center cartrige and the turbine housing. I did not note any oil in the exhaust.
now could it be that the oil just got to hot and leaked out? I am running 5w-30 mobil 1. should I be running a different weight oil? I know that a few time on one tune the turbine got extremely hot, more so then normal. recently it has been pretty steady.
also I take it play in the turbine side bearing isn't normal is it?
