ryanblacksvt
I'm the Dork who ran 14.9 on PassTime. :)
No actually the quaife just has a lifetime warantee, the Torsen has better torque biasing, so the better one is Torsen, and besides I already have a torsen so I am not buying another atb.
I think the spec stage 4 might be overkill. I don't recall reading anything about someone running out of holding power on the stage 3s.
Same thing with forged rods, have not been the weak link in even boosted 3L setups. But I suppose there is something to be said about having everything BUILT up.
Turbo blanket if not included in kit from Nautilus. Will really help with keeping underhood temps down.
Battery relocation kit from summit. Maybe a turbo timer.
You will most likely want some gauges if you dont already have them. Easier to install with engine out too. EGT, Wideband AFR, Xcal2 for tuning, IAT temp before and after intercooler would be nice to have as well.
Sorry if you already have this stuff. Just trying to recall everything I have bought.
You will probably want to do something with the engine mounts and some type of frame stiffening.
Check the lower control arms and make sure the bushings are intact.
You will deffinitely need some track tires. I took my CSVT to the local 1/8th street drag event and could not get any traction due to all the soft rubber on the track.
I would also try to drop some weight out of the car.
Torque Capacity:
2.5L
Stage 1 = 270
Stage 2 = 340
Stage 2+ = 385
Stage 3 = 440
Stage 3+ = 540
Stage 4 = 450
Stage 5 = 610
In the end, you probably won't exceed the torque capacity of a Stage 1/2 with either application. With the Stage 3+, you are paying for a clutch that can handle more than a Stage 4, but is as easy to drive as a Stage 2.
Thanks
