sounds like a lie to me. i drove my car for a whole day with my bottle heater on and it only ran the pressure up to 1150.
the pop off cap on the valve for ANY nitrous system will pop at no lower than 3000 PSI. the NX bottle valve i had had a pop off set for 4000 PSI. four thousand psi? at 98 degrees Farenheit a full 10 LB bottle would go to 1000 PSI. so you would have to have 300 plus degrees Farenheit of temperature to pop off the safety. so the safety failed, either way, something WAY out of the ordinary had to happen. a bottle heater cannot supply enough heat to make a nitrous bottle explode! plain and simple! people hold torches to nitrous bottles for 10 minutes and nothing happens!!!!!!
you can show me your stupid link all day long. READ UP ON YOUR NITROUS FACTS BRO. a 10LB capacity nitrous bottle is 27 LBS of steel. its gonna take a CRAP ton of heat to blow it up!!!! sorry dude. bottle heaters can't make that happen. the stories you are reading about are missing key facts, they really must be. there's no way it can get high enough to blow up a bottle and do that much damage. like i said, i'm not going to argue with you. i researched nitrous, and spent countless hours arguing this cap to people. i spent hours and hours on the phone with nitrous express to make sure i went about nitrous usage the right way. on the days i went out to play i had the bottle heater on and the bottle closed for hours on end, in 90 degree plus heat in the trunk of my car. doesn't happen!
