Bignose94015
- Joined
- May 5, 2011
- Messages
- 8
So I am a little leary of porting with the Bazuki plates. Will the Nautilus intake adapter let me retain my svt intake and smog equipment?
Thanks
Eric
Thanks
Eric
Yes. I think they had the LIM that went from oval port to split port allowing the use of svt intake manifold on the 3L, which I believe would require a tune since it removes the IMRC. And recently I think they came out with a plate that transitions split port into oval port allowing use of 3L intake manifold on 2.5 split port heads. Although their website doesn't list either, so I could be totally wrong.
Without the IMRC he will have a check engine light and he will fail his smog test so no the intake adapter will not work for him.
I think it depends on the state. Some check the ECU for tunes.
I live in Colorado and I put on headers and had a pain in the ass passing emissions because the pre-cats were gone leaving me with one cat instead of the required 3. I can't believe Cali would pass you with only one
