mrspindlelegs
I've done a fairly thorough search of the forums and haven't found the answer to the following question:
Why doesn't the NPG CAI MAF Adapter mount flush with the MAF?
If I leave the factory rubber gasket on the MAF, I don't see how the MAF adapter will ever seat properly. Quick dial caliper measurements show that the aluminum shoulder underneath the gasket is wider than the opening on the MAF adapter. The only conclusions I can draw are:
1. The MAF adapter I received is incorrectly made (should have a much wider opening to mate properly with the MAF).
2. There should be another adapter/spacer that also functions as a gasket that goes between the MAF and the MAF Adapter. The picture of the kit on the NPG website does not show this so I don't place much weight on this possibility.
3. Everybody has been removing the rubber gasket and having that aluminum shoulder machined off so that the MAF and the MAF Adapter mount flush to each other. Pictures of other peoples NPG CAI installations show flush mountings which seems to support this supposition.
I don't want to start butchering my MAF if it turns out that this isn't necessary.
Your thoughts?
Your thoughts?
