For Sale MTX75 Trans Parts (shell, in/output shafts), 05 3L Camshafts, T3 Turbo Ypipe for Mazda headers
2000ZxT
nh
I have a bunch of stuff I want to get rid of, if you are interested send me a PM and I can get you pics and a shipping quote. Parts ship from NH.
2005 Taurus 3.0L Camshafts, chains, guides and tensioners: missing some guides iirc would be best to just update your later style chain cams to the newer camshafts.
$35
1999 MTX75 Transmission Housing - Empty - Good core for an LSD build so you can make the case pretty.
$30
Just a note...if you want to repair syncros on a contour MTX75 you cannot buy parts...everything has been updated to a later style and if you try and repair the sncro for example you have to buy almost everything associated with that gear. It was going to cost me $350 to get the parts needed for just 3rd gear.
MTX75 Input shaft - bad 3rd gear synro everytihng else good.
$20
MTX75 Output shaft - Perfect condition everything works flawlessly, this was from the trans I used to fix my transmission
$30
Differential Ring Gear 4.09
$10
1999 Shift tower and shift forks
$10
T3 Low Mount Turbo Y pipe for Mazda headers, you can get the OBX ones now for $350. Comes with 3" downpipe and external wastegate, pretty much just looking for this to go to good use I dont wanna cut it up for parts. Rebuild my turbo kit to topmount T4.
$150
This is what you get minus the turbo. So for $500 you would have stainless headers, turbo ypipe, downpipe, wastegate...add a turbo and plumbing and a charge pipe and your boosting.
It has 3 bungs for the o2 sensor so you can tune to each bank, than to both banks post turbo.
CLASSIFIEDS RULES
Last Updated: 7/20/22
