Unfortunately, I guess I'd suggest dropping the pan again and actually checking the rod bearings.
Rick
Rick
Okay, oil is now back in the car and the oil pressure has gone unchanged. The "time bomb" continues ticking.
Wow, first thought was a rod bearing thrust surface getting sliced off, but then Warmonger's comment on bearing magnetics have me questioning it... but after further review, I believe that the only steel used in these bearings is the backing of the main lead babbit area and not the side thrust surfaces. Being made of lead/brass/nickle, those side thrust pieces wouldn't be magnetic. Anyone have a new set of Clevite 77 bearings that they can test with a magnet to see if the edges pull???
It looks just like the rod bearing pieces I pulled out of Silvie. :-(
EDIT: I've failed to find a picture online of bearing construction, but I know I've seen one before of the innter steel only going down the middle...
Yes, we need more close-up pictures of the material.then take some good pictures.
