Everything is OBO
Accessory belt tensioner removed with 100k to replace a slipping belt, belt still slips so im assuming its the belt
Stock Plug wires (100k) No missfires when removed
Blue Piece of tubing from aftermarket intake pipe
2-bolt LCA's removed at 100k, ball joints good, bushings so-so
Optimized Duratec ATX TB, will be pulled off the car shortly after I finish the one im working on, good TPS
Duratec 3L TB with TPS taken off of a low mileage Taurus - This TB can be modified to fit on our cars, check over on NECO for the how-to
Parts Plus brand drivers side outer tie-rod end for a Pre-98 - In good shape, only used for probably 10k, but the boot is torn
Stock rear swaybar
Hubs for rear disc brake cars with wheel bearings
Turn signal stalk, removed at 105k, only turns off from left hand turns, comes with relay
Brand new return fuel pump sock
98+ Contour sail panels painted black, decent paint job
Pre-98 Antenna Bases, in good shape
Fram air filter, ~15k on it, looks almost perfect, for stock non-svt airbox
PM me if you're interested in anything...
I'm willing to let a lot of this stuff go for the cost of shipping... I need to clean out the garage for a summer project... ;-)
