CSVT#49
Addicted CEG'er
Is it worth my while to purchase a Lightning 90mm MAF for a forced induction car? I found a great deal on one for $99 which includes the adapter plate.
if your talking about mine its in the factory location.
I haven't purchased anything for my kit yet. I'm piecing parts together. I'm not sure if I'm going to have an intercooler or not yet.
There is no realistic benefit to getting a MAF larger than your throttle body. If your throttle body is 65mm and the MAF is 180mm, then guess what, you are still bottle-necked at 65mm.
I would concede to say that something a hair-larger than the TB would be okay, because you are compensating for the material directly in the path of air-flow in the MAF it self. Such as the screen, sensor, mounting plastic, etc. The same could be said for the throttle plate in the TB as well though.
It's not the size that's the issue here. The stock MAF sensor maxes out (peggs 5V) around 300whp. People pick up the 80mm MAF or 90mm MAF from the Lightning because they are calibrated for a larger range of air flow meaning they won't pegg out. If the MAF peggs out you will run lean because more air is getting in than can be metered.
i put my stock maf sensor into my pro flow housing (75mm) so am i going to still peg at 300 WHP?
Couldn't be said any better.
You realize this is the Forced Induction branch right? onder: Were not talking about how much air we can force through a mass air flow sensor, were talking about fuel delivery. Stock MAF isn't going to cut it.
If this were naturally aspirated, I would totally agree with you, but like Blackcoog said, the stock MAF is only good for about 300 whp.
Yessir.
no way man. i have a wideband, and i have a pro flow. i wouldnt put a 90mm lightning maf on my car, its still got the shaft going all the way through. the pro flow i have has the small tube in the housing, and the sensors drop right in. i will have it tuned with the stock MAF this spring, and if i need one that will read further, i'll drop a sensor in off a 90mm.
