Let it be said, for one reason or another my trunk has very little resistance to it (one other problem I have to find a fix for...). You can simply tap it and let it fall to close it, which can be annoying. However, people see the need to slam my trunk even after I tell them not to . To sum it all up, between pure age and this practice, my rear tail lamp lenses are cracked to hell.
I was curious if there is (longshot) any sort of replacement lens that one can get for the car? (2000 Mercury Mystique) I don't know if you can just use a solvent to take the stuff holding the lens off, and I would rather not replace the entire units for these minor cracks. Would I have to go to a junkyard and pry the suckers off of the older cars? I would rather use the reflectors and housings I have now, because even given the cars age they are almost immaculate except for the obvious and work quite well.
Thanks for your time and insight in advance.
