Nakalaka2
Yeah, so on my drive home last night, I was sitting still with the foot on the clutch, car in 1st gear, and bam, it killed as if there was no clutch. I let off the pedal and there was no resistance. Depressed it again and it was fine. Started the car and continued my 15 minute drive home. Over that drive though, it got progressively worse. had to pump the •••• out of the pedal do get it to get into gear, made it home, and absolutely no pressure. I'm not good with diagnosing anything, especially with this tight as hell engine set up, but i got under the car when I got home and sure enough, had some fluid leaking out the front end of the engine (towards the front bumper). I figure its got to be one of the cylinders or the lines? but i have no idea where my Master and slave cylinders are located... otherwise I'm probably gonna limp it down to the dealership and have em replace the cylinder set.
I did hear that the master cylinders out of the 2000ish explorer are known for leaking, so is this possibly an issue that a lot of others have?
Otherwise im guessing that after 185k, they've finally had enough.
Who knows, if i cant fix it myself, im hoping its not gonna cost more than a few hundred dollars...
Any help and advice would be appreciated, thank you guys.
