rexxdoggy
So, I started this today, and finished today. 5.5 hours, that's good time! My last set was a quad retrofit with Cougar projectors high and low. Im glad I went that route first because I learned A LOT. This second build I went with just the low beam projector and kept the stock high beam. The projector is actually bixenon so it will be wired up to run quad highs when my connectors come in. It's a 2.5" bixenon projector with a clear lens. It has the outdated shield so the cutoff and foreground isn't as good as the revised version. This time, I mounted the projectors to the reflector so I could retain the aiming characteristics. And what was cool with these 2.5" projectors was that I was able to keep and reinstall the rubber grommets that seal the back where the bulbs are with a little bit of cutting modifications. ANYWAYS! Picture time!
