injector size
PuckPuck
Windsor, Ontario, Canada
I'm aiming to achieve 420hp or so with turbo... by my calculations that puts me in a 60# injector range...
is that right or did I completely screw something up here...
From my calculations:
#60 would be good for ~720hp
#42 would be good for ~500hp
Those numbers are assuming a .5 BSFC though.
turbos should use a .6 to .65 BSFC... which would make it a 60# injector
i know a few others are running quite high numbers what injectors are in those beasts?
36# injectors will make 350 wHP easy. :rolleyes:
42# injectors will make over 400 wHP on hour cars. I can't speak for other cars but no one has maxed either out yet.
I would put in the 42s if I were you.
