GreaseyMonkey
i'll have to get a picture of it tomorrow, but i was wondering if anyone else has had this problem:
the tiny yellow tab that inserts with the pin to the lever that controls the secondaries opening (the pin connects to a spring, the spring to the IMRC cable), has broken off, and will not stay in place once the car moves. i've been to the junk yard and tried pulling one off several duratecs in the yards, but they break pretty consistently and i've not seen a way to get them.
my question is this: has anyone else had this problem? and what did you do to fix?
the thing i'm pretty close to doing is getting some steel epoxy and putting a bead of it on the end of the pin so that it can't retract back through the hole. it will be permanent, but i don't think that will be a problem.
