TheMexicanJob
Banned?
We all know about about the contour's rear door squeak. most use PB Blaster, WD-40, or white lithium grease. These may fix it for a little while but it will return.
Here's how i attack the problem, and i've never had a squeak return.
Sand the metal bar that connects the door frame to the b-pillar.
Clean off the sanding dust with air or a dry rag.
Then use a Q-Tip and put a good amount of vasaline on the metal bar and open/close the door to work it in, then add more til the squeak goes away.
That should take care of the squeak, i did this with my first tour and after a year and a half it was still squeak free.
