We ported the intake of the 3.0 (from 2001 Sable), and modified the block as needed (brackets, installed 2.5 oil pan and modified pickup tube to fit 3.0 mounting points, shortened the stick out shaft on the transmission side; installed the 2.5 flex plate and timing cover, installed 2.5 LIM and UIM, etc.)
With all the work done with the engine open, it is inevitable that 'stuff' got in the engine (oil and coolant channels).
To avoid messing up the new engine (logically, we put fresh oil, filter and fresh coolant in), what is the recommended 'flushing' procedure?
Should I crank and run a very short time (5 minutes), then drain the fluid?
Could I ran the oil through a filter (what works? Coffee filter seems to be too fine. Clean cloth?) and reuse (since it is obviously not 'burnt'/used at this point)? Just trying to save $15 for all new oil and throwing the fresh oil out).
Or will whatever particles got into the engine be quickly caught by the oil filter?
