how do I replace rear wheel bearings?
compudude86
Algonquin, IL
I got my rear disc knuckles today, and I would like to replace my bearings so that they don't go later. how do I replace the bearings on the rear knuckles?
when you buy them they should be already inserted in the hub and all you have to do is unbolt the old ones and re-bolt the new ones.
mine didn't come with a new dust cover. i'll look tomorrow to see if there is an easy way to remove it without destroying it.
pretty easy, well unless you are a rust belt person
In the desert we just put a screw driver in the gap and pop them off, or grab hold of them with a channel lock pliers and pop them off.
