Nerawkas
thanks, ill get started right now.
The 1131 and 1151 mean you are lean, maybe vacuum leak. The 401 may mean EGR passages clogged, I hear that's common on sixes. Sensor change out will not touch the first 2 at all, that's not what's making them. You either have old wore out O2 sensors or airleak of some sort. Running lean won't cause the EGR codes, but won't help either, can make NOx go up a bit.
This got me thinking. If you are using higher than 87 octane gasoline, try using 87 octane and see if it will help. You might get some engine pinging but at least your NOX levels will be lower and it might be what helps you pass emissions....Other things that can lead to high NOX include a very (and I mean very) lean mixture, over advanced ignition timing, or anything that will cause hotter than normal combustion. NOX is formed by combustion being so hot that normally inert Nitrogen is scorched.
The codes 1131, 1132, 1137, 1138, 1150, 1151 & 1152 all have similar causes / fixes as code 1130. 1131 & 1151 both indicate lean conditions. There are many different causes. The following list pinpoints different areas to check. They are electrical, fuel system, Induction, EGR and base engine. This will give you all the areas to look at. Some are very easy to inspect while other a bit more difficult. If you can print the list, then use it to do your checks. I believe some of the things you have checked / changed have no bearing on your troubles. If you have already completed some of the items check it off the list. Tracking down problems like you are having is easier if you are systematic. The trouble shooting guide below is what a Ford garage would do. I would suggest you try the same format. It will help eliminate what is and is not relevant. DanThe 1131 and 1151 mean you are lean, maybe vacuum leak.
