Murtaza
Hey guys, I had bearing noise in the right side of my 96 GL so I took off the hub and got new bearings pressed out an in at pep boys. The problem I ran into now while finishing up is that after I connected the axle back onto the hub, I reconnect the ball joint to the hub but the strut has no room to get back on. Likewise, with the strut connected first I try to get the ball joint back in but theres nearly 1/2 inch gap. I took the control arm off hoping I could connect the strut and ball joint then just push the arm back in but that's not working. Anything else I should try before I hand it over to a mechanic?
