95_Mystique
ok, i see.
so is there a way to drill a hole or weld something on for the EGR pipe?
Sorry to jump in late but I was browsing around and came across this thread. I ended up putting the cougar header on my 96 Zetec.
I recommend the cougar header, it was really easy to install. I also went with a magnaflow (carsound) cat.... you will want to use a 2.25" opening and have it welded. The cougar header is also 2.25" at the collector end.
The haynes manual says you have to drain the coolant. Is this true or a myth?
For the egr....
You can cut the tube that goes to the cat and leave it open, it may trip a code and run a little less efficient, but your car will run fine (i ran this way for awhile). I didn't like the idea of having an open tube though so I ended up cutting a hole in the header's collector pipe and routing the egr tube that I cut down to the header... now the system operates as intended and with a header.
