Dyoel182
I noticed today that my revs hang and then slowly drop when I put the clutch in to shift at speed so the clutch is always slipping a little. Is that a symptom of the IAC, the TPS or maybe the throttle body?
Throttle Hang.
The fix is in the Duratec Maintenance forum, under the "READ FIRST" thread (which you've not done, I can tell.. LOL)
Its not electrical.... The problem is one of reverberation and/or a poorly maintained IAC. either/or/and.
While I agree that the IAC may be a culprit, it has nothing to do with the electrical portion of the IAC, and everything to do (if the IAC is, in fact, the culprit) with a DIRTY/STICKY IAC.
Of course, this is IF the IAC is the problem.
I agree with the above.
I corrected the problem with a restrictor in the egr hose.
But this is a 'bypass' fix leaving the original culprit yet to fix.
...I still have my TH on my car. I don't mind it very much.
what mazda do you own? f2 or f2t powered perhaps?
I found it most annoying in traffic, when it made a more noticeable impact on smoothness and driveability. Now that it's gone, the car is much more enjoyable.
