azbobbybooshay10
With my tranny exploding and the powertrain needing to come out, I figure this is the best opportunity I've had to make the leap to 3L power, while sticking my 2.5 into a Contour for use as a DD. My Cougar is far, far from a DD-type vehicle and I have no desire to just put the 2.5 back in, especially with my intended purpose for the car.
The car will be probably 50% or more for open track use on road courses, so good top end is more important for my uses. The more power the higher in the powerband, the better.
A friend did an MPV swap in his Contour, and in doing research, the MPV engine appears to be the "most straight forward" swap out there. The only issue I've heard about is the manifold clearing the hood. I'm not sure how the Cougar engine bay/hood line compares to a Contour, so that's something I'm looking for an answer for.
A few bullet point issues that are slightly clouding things up for me.
So basically, from what I can tell, the full 3L would be best for me, other than the uncertainty of the UIM fitment. I will be deleting the EGR and getting a proper tune before I really do any driving, so that is something I am already planning for. I'm just looking for a little guidance on which direction I should start pursuing, as you guys here on CEG seem to do a LOT when it comes to performance and 3L swaps. Thanks in advance, and as I start going on things, I will definitely be sure to be updating my progress.
- I do not have ANY SVT parts on my current 2.5. Doing the split-port matching setup would mean I would also need to source an SVT UIM/LIM/TB in addition to the engine.
- My Cougar is return style, so I would need to mod the fuel rail/lines to accommodate. I see the NPG adapter and would most likely go with that if it is compatible with a complete 3L (not split-port)
- I want the car to rev, as mentioned before. I had considered going ahead and trying to go with SVT cams, but have heard that the 3L cams are actually fairly comparable in power.
- I hate IMRC's. The trans exploded before I could put a new IMRC in, but both Cougar's I've owned have had IMRC issues and I can't stand the damn things and their poor longevity, especially in Arizona heat. Going full 3L would eliminate this and make me VERY happy.
