This is now the official GB for the gauge color change. Total is going to be $50. This will include:
Now your options on how this can be done:
I currently do not have any core clusters I can loan out, so sending me just the faces is your best bet. i can mail you a photocopy of the gauge faces to stick on temproarly if requested.
Instructions for gauge/face removal:
To remove the gauge cluster from the dash:
Pictures of my current gauges:
To make this more effective, please post your name and your color choice.
Payment instructions:
Paypal is robisc31@potsdam. I accept all forms of payment via Paypal.
I also will accept checks or money orders. Please add yourself to the list and PM me for my address.
___________________________________________________________________________________
This GB is much easier on everyone if you post and are DEFINATELY 100% in so I know the correct amount of LEDs to order. Any questions, please PM me, I will most likely be checking this multiple times daily.
Edit: Option 2 above changed. Forgot to add bulbs in that option.
- Removal of green from stock gauges.
- Paypal fees.
- Shipping.
- LED installation in color of your choice, in:
- Green
- Blue
- Red
- Orange/Amber
- White
- UV/Blacklight
- You can remove your entire gauge cluster and send it to me.
- You can remove the individual gauges and bulbs, and send them to me.
- You can remove the gauge faces and bulbs, and send them to me.
- Pop out the Contour logo in the dash, and the defroster switch holder.
- Unplug the multiplugs.
- Remove the 5 screws holding the bezel in: one behind the defroster switch, 2 above the lexan cover, and 2 behind the Contour logo.
- Remove the bezel, then unscrew the 5 screws holding the cluster in.
- Unplug the 2 multiplugs and pull the cluster out.
- You need to pop off the lexan cover by pushing on the 5 black plastic tabs holding it in. It takes a little while, but you'll get it. Keep pulling on the cover and pushing down the tabs with a screwdriver.
- Remove the torx screws holding in the gauges. You can use a flathead screwdriver if you don't have a torx bolt, but be careful.
- Pop out the gauges gently with a flathead screwdriver, starting with the speedo, then the tach, then the fuel and temp gauges.
- Remove the needles with 2 spoons. Put one on each side and gently push up till they pop off. If you are careful, you won't have to recalibrate them.
- Take a small screwdriver, or something very thin, and get it under the edge of the gauge face. Go around the entire edge carefully seperateing the glue.
- Finally, VERY carefully peel the face up and off the plastic.
- Any 5 bulbs will do. But you want to try to get the right ones. The best way to find them is twist a bulb out, and hold the cluster up to the light. See what is light up. If you send me the whole gauge cluster, I'll remove them for you and mark them with a Sharpie.
